RAT-LOOK.COM • View topic - subStandard 8
 It is currently Tue Sep 29, 2020 12:54 am
Post new topic Reply to topic  [ 222 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: subStandard 8
PostPosted: Sun Jan 13, 2013 2:01 pm
you know there is a 105e anglia on passion ford running a 2.1 pinto thats been terrorising south london for 20 odd years putting out 187bhp at the wheels i remember the car from years ago my point is most of the power comes from the harris cam and headwork worth checking his thread out for specs ideas maybe think it was using 2.8 pistons aswell ;)
PostPosted: Sun Jan 13, 2013 10:40 pm
yeah the cologne pistons are what everyone uses in 2.1's, that some serious oomph out of a pinto
ill try find his build thread, cheers
ill be aiming to nudge the cheeky side of 150
PostPosted: Mon Jan 14, 2013 1:47 am
Well done sourcing a 205 block. I would love to see some video of the finished item at work. :)
PostPosted: Fri Jan 18, 2013 1:06 pm
ill make a video once its back on the road as it is now. the last of the required parts turned up today but its snowed under!!! will try get it finished this weekend.
The sourcing of parts is going to take a while, I've got pistons, rods and rings on the way
next step on the new engine will be saving to pay for the machining of the block to accept the new rods and pistons
PostPosted: Tue Feb 05, 2013 9:24 pm
BIIIG update, snow, whitewalls, exhaust mods, first show of the year, more custom art, ratlook roofracks.... enjoy
Over the winter of 2012 whilst the weather was poor i decided to iron out some of the problems i have with the car
1) the prop clips under heavy acceleration caused by being too tight to the tunnel and crappy lever shocks.
solution. Tunnel mod, turret the back end and fit adjustable shocks!
2) the cars so darn low that the exhaust was 'removed' by a pesky speedbump on more than one occasion!
solution, new exhaust system and fabricate a section through the sill for the pipe to pass!
And here we are this week, snowed under, couldnt resist going for a trial run on the new suspension..... Its so much now, its an animal in the snow though!
first show outing of the year.
all ready for a show.
roof rack mods
prepped my spare bonnet for some love from Reborn to be wild. Her stuff really is top notch!
PostPosted: Thu Feb 07, 2013 12:40 pm
glad to see this back on the road and loving the side exit exhaust, me personally i prefered it without the roof rack but then i hated them when it was the thing to do in the aircooled scene aswell but each to their own nice work :tu
ps hows the 205 build going
PostPosted: Thu Feb 07, 2013 7:07 pm
cheers for the comment.The rack is very marmite, im not that keen on it to be honest,
Its not going to stay on there permenantly, (eats fuel as well)
The 205 build will be uber slow, got boring financial stuff to do alongside.
Ive got a slim inlet manifold for twin 45's, thats the only new part ive purchased.
PostPosted: Tue Feb 26, 2013 5:47 pm
Bit of a change of plan, think im gunna sell off all the parts ive acquired for pinto building,
im supposed to be doing boring stuff like saving for a house and the cost of the pinto build just doesnt make sense.
still going to go for bigger power but in the form of a zetec lump i think,
Gunna run it this show season as is with the stock 2 litre pinto, then hunt out a zetec donor for a winter switch around.
PostPosted: Sun Apr 14, 2013 6:52 pm
Just got some of the photo links to work from earlier in the thread.. Well pleased it made car of the month! :D
Rob
1954 Standard 8 SOLD!
1952 Standard Vanguard SOLD :(
1987 BMW 525e
1966 VW Camper
PostPosted: Fri Sep 06, 2013 9:22 pm
heres a few pics from various sources of rrg13, was awesome fun! learnt alot about what I need to do to improve handling too!
[img src="http://i163.photobucket.com/albums/t304/2309andy/1097582_10153186806800347_1303956956_n_zps3f1ef876.jpg" alt=" "]
[img src="http://i163.photobucket.com/albums/t304/2309andy/563388_10153118634110212_2018747509_n_zps98a1adfe.jpg" alt=" "]
[img src="http://i163.photobucket.com/albums/t304/2309andy/1080377_10153186801000347_218004532_n_zps346b632b.jpg" alt=" "]
[img src="http://i163.photobucket.com/albums/t304/2309andy/IMG_0517_zpsf6cbc761.jpg" alt=" "]
PostPosted: Fri Sep 06, 2013 9:48 pm
Good to see it back again. What's the running gear now? Still the old Pinto lump?
PostPosted: Sat Sep 07, 2013 8:34 am
yeah still on a stock pinto
building the other engine is costing loads! going to do an interim upgrade inbetween changing engines.
twin 40s and a fruitier cam going in soon
PostPosted: Sat Sep 07, 2013 8:36 am
also going to finish the steering rack conversion, going to adjust the camber that the front wheels sit at and make it adjustable as i had zero front end grip on a track with all the camber im running!
Rear axle swap is also planned for the winter, should be epic for next year!
PostPosted: Sat Sep 07, 2013 11:18 pm
sounds good!
car looks great :tu
VW Golf MK3 rat project!!!
PostPosted: Thu Sep 12, 2013 8:22 pm
topic subscribed, thank you for a very good 9 page read.
PostPosted: Sat Oct 05, 2013 1:03 pm
classic rat that id love to have in my dream garage :tu
PostPosted: Sat Nov 16, 2013 7:40 pm
Big changes since last update
Had a major disagreement with the law of gravity. Excessive speed + heavily cambered country road + bumps = negative ground clearance and damage!!
Mashed the exhaust, lower arms, sump and mangled an engine mount as well as snapping the coolant takeoff to the inlet manifold. :(
Seeing as i had unplanned downtime seemed a no brainer to improve all the niggly issues i have with the car as well as repair the damage.
Problems...
Steering box is awful and play is a big issue at speed
........... solution..... Fit a steering rack
Camber on front wheels is excessive resulting in no front end grip and understeer on way into corners - was silly at RRG13!
........... solution..... Modify lower arms to correct geometry
Rear wheel/tyre combo is too narrow, cant put power down
........... solution..... Fit rediculously wide rear wheels
Bored with power output of stock motor with stock weber carb
........... solution..... DCOE's and a few other tweaks
Suspension is too soft
........... solution..... Stiffer springs and ARB on front
So heres a few update pics
DCOE clearance mods
Wide wheels :)
Steering rack extensions i made to use with a mk1 escort imperial rack - all splines and threads the same as the original box, rods etc
cheers
Andy
PostPosted: Sun Nov 17, 2013 6:48 am
Holey cow!!!! Hope goes well. Would be nice to see this in the metal again.
PostPosted: Sun Nov 17, 2013 9:59 am
Should be back on the road early next year, Mods are pretty much complete to get the DCOE carbs in, just need to paint the areas of the engine bay and battery tray that needed modifying. Steering rack stuff is pretty close too, finally sourced all the right bits to join the necessaries together. Looking at ways to lift the subframe up into the car a bit is whats taking a while there. Found what must be the only area of rot in the car in the base of the A pillar whilst i had the wings off. Repairing that will take a bit of time but nothing too major.
The main bulk of work will be getting them rear wheels in, rear axle swap was always planned but to get the maximum benefit from upgrading axle i will need to convert from leaf spring to coil spring. This isn't a horrendous amount of work but all the geometry will take a lot of measuring, remeasuring, probably have to make a jig to get everything true then need somebody to make me some custom halfshafts.....
Itl be ace when its done :)
PostPosted: Mon Nov 25, 2013 10:09 pm
sounds great :tu
Users browsing this forum: No registered users and 36 guests
